WFS 1.1.0 SHAPE-ZIP output generates shapefile with lat/long instead of long/lat
Key: GEOS-3657
URL: http://jira.codehaus.org/browse/GEOS-3657
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.7.6
Reporter: BartV
Assignee: Andrea Aime
Priority: Minor
Projection is EPSG:4326 (WGS 84)
Example request:
=> Will produce a shapefile that is inversed (lat & long switched) in ArcGIS
=> Will produce a correct shapefile in ArcGIS
This is in contradiction with this page:
http://docs.geoserver.org/1.7.x/en/user/services/wfs/basics.html
"...GeoServer, however, in an attempt to minimize confusion and increase interoperability, has adopted the following conventions when specifying projections in the follow formats:
EPSG:xxxx - longitude/latitude..."
