Namespace is ignored when editing/removing layer
Key: GEOS-3658
URL: http://jira.codehaus.org/browse/GEOS-3658
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.0.0
Reporter: Miles Jordan
Assignee: Andrea Aime
This issue occurs if you have two layers with the same name, in different namespaces.
Example: You have two layers 'bruschetta:tomato' and 'sandwich:tomato'. If you click on 'sandwich:tomato' it will take you to the edit page for 'bruschetta:tomato'. Also if you try to remove 'sandwich:tomato' it will actually remove 'bruscetta:tomato'.
And I like bruschetta so want to keep it
