[Geoserver-devel] [jira] Created: (GEOS-3660) Mosaic reprojection appears to be broken
                 Key: GEOS-3660
                 URL: http://jira.codehaus.org/browse/GEOS-3660
             Project: GeoServer
          Issue Type: Bug
            Reporter: Andrea Aime
            Assignee: Simone Giannecchini
            Priority: Critical
             Fix For: 2.0.1
Following up a report on the users mailing list it seems the mosaic reprojection is not working anymore.
Using the reflector to get a reprojected image quickly (using the demo data), if I try with a vector layer:
http://localhost:8080/geoserver/wms/reflect?layers=topp:states&srs=epsg:900913
everything works fine but if I try with a raster one:
http://localhost:8080/geoserver/wms/reflect?layers=nurc:mosaic&srs=EPSG:900913
I only get a gray image.
Also checked out with uDig to make sure it was not an oddity of the reflector and got a gray image there
too.
