Native SRS from PostGIS not recognized
Key: GEOS-3681
URL: http://jira.codehaus.org/browse/GEOS-3681
Project: GeoServer
Issue Type: Bug
Components: PostGIS
Affects Versions: 2.0.0
Environment: GeoServer 2.0.0a (WAR distribution), PostgreSQL 8.4.1, PostGIS 1.3.5, Sun JDK 1.6.0, Ubuntu Linux 9.10
Reporter: Peter Becker
Assignee: Andrea Aime
We are trying to upgrade our GeoServer 1.7.6 installation to 2.0.0, but GeoServer fails to identify the native SRS for our database. The result is that on the layer creation page the "Native SRS" field stays empty and the layer will not be rendered in the preview.
Turning verbose logging on results in this SQL query being shown:
SELECT "id","area_type",encode(asBinary(force_2d("the_geom"),'XDR'),'base64') as "the_geom" FROM "public"."areas_in_time" WHERE ("the_geom" && GeomFromText('POLYGON ((150.68856835939002 -29.56075390625, 150.68856835939002 -24.804246093750002, 154.51043164064 -24.804246093750002, 154.51043164064 -29.56075390625, 150.68856835939002 -29.56075390625))', null) AND ("area_type" = 'bay area' OR "area_type" = 'catchment'))
which returns an empty result set due to the "null" value for the SRS -- it works fine if I replace the "null" with the expected "4326".
If I try to change the handling of SRS to "Reproject Native to Declared", I get this stacktrace:
org.apache.wicket.WicketRuntimeException: Method onFormSubmitted of interface org.apache.wicket.markup.html.form.IFormSubmitListener targeted at component [MarkupContainer [Component id = resource]] threw an exception
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:194)
at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1239)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:532)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:145)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at sun.reflect.GeneratedMethodAccessor92.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:269)
at java.security.AccessController.doPrivileged(Native Method)
at javax.security.auth.Subject.doAsPrivileged(Subject.java:537)
at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:301)
at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:162)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:283)
at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:56)
at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:189)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:185)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at sun.reflect.GeneratedMethodAccessor91.invoke(Unknown Source)
at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:243)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at sun.reflect.GeneratedMethodAccessor90.invoke(Unknown Source)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at sun.reflect.GeneratedMethodAccessor89.invoke(Unknown Source)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at sun.reflect.GeneratedMethodAccessor86.invoke(Unknown Source)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:849)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:454)
at java.lang.Thread.run(Thread.java:636)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor163.invoke(Unknown Source)
at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:183)
... 131 more
Caused by: java.lang.IllegalArgumentException: Argument "sourceCRS" should not be null.
at org.geotools.referencing.operation.AbstractCoordinateOperationFactory.ensureNonNull(AbstractCoordinateOperationFactory.java:732)
at org.geotools.referencing.operation.BufferedCoordinateOperationFactory.createOperation(BufferedCoordinateOperationFactory.java:247)
at org.geotools.referencing.CRS.findMathTransform(CRS.java:1026)
at org.geoserver.web.data.resource.BasicResourceConfig$ReprojectionIsPossibleValidator.validate(BasicResourceConfig.java:225)
at org.apache.wicket.markup.html.form.Form.validateFormValidator(Form.java:1976)
at org.apache.wicket.markup.html.form.Form.validateFormValidators(Form.java:1988)
at org.apache.wicket.markup.html.form.Form$23.component(Form.java:2007)
at org.apache.wicket.MarkupContainer.visitChildren(MarkupContainer.java:830)
at org.apache.wicket.MarkupContainer.visitChildren(MarkupContainer.java:845)
at org.apache.wicket.markup.html.form.Form.validateNestedForms(Form.java:1999)
at org.apache.wicket.markup.html.form.Form.validate(Form.java:1888)
at org.apache.wicket.markup.html.form.Form.process(Form.java:846)
at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:808)
... 135 more
[BTW: copying that from the website is useless due to missing linebreaks, this comes from the log file]
Changing it to "Keep Native" just quietly fails to work -- saving the change and going back in I still see the "Force Declared" and I can't see any error message in the UI or in the log (with verbose logging enabled). That might be a separate issue.
