app-schema FeatureChainingWfsTest failure on some platforms
Key: GEOS-3689
URL: http://jira.codehaus.org/browse/GEOS-3689
Project: GeoServer
Issue Type: Bug
Components: Application schema
Affects Versions: 2.0.0, 2.0.x, 2.1.x
Reporter: Ben Caradoc-Davies
Assignee: Ben Caradoc-Davies
Priority: Blocker
-------- Original Message --------
Subject: [Geoserver-devel] How can hudson show successfull geoserver builds ???
Date: Tue, 1 Dec 2009 22:26:31 +0800
To: geoserver-devel@lists.sourceforge.net
Hi all
I am pretty confused about our offical hudson build server which shows
perfect builds for geoserver-trunk and geoserver-2.0.x
Since some time, I never succeeded with with a geoserver build using SUN sdk
or IBM SDK or OpenJDK.
Investigating further into FeatureChainingWfsTest>>testDescribeFeatureType
if found the problem at line 160
assertXpathEvaluatesTo(AbstractAppSchemaMockData.GSML_URI,
"//xsd:import[1]/@namespace",doc)
which tries to query the "namespace" attribute of the second "import"
Element. According to W3C, indexing starts with 1 and not with 0, it has to
be
"//xsd:import[2]/@namespace",doc)
After fixing and a retry, line 188 causes the next problem.
@Ben, could you have a look at this. I do not want to open an issue because
of the successfull hudson builds.
