[Geoserver-devel] [jira] Created: (GEOS-369) Filter Functions don't work, ExpressionSAXParser misses implementation
         Key: GEOS-369
         URL: http://jira.codehaus.org/browse/GEOS-369
     Project: GeoServer
        Type: Bug
  Components: WFS
    Versions: 1.3-rc1
    Reporter: Thijs Brentjens
Assigned to: dblasby
    Priority: Minor
     Fix For: 1.3.0, 1.3-rc2
The WFS-Capabilities say that there are several filter functions implemented (like: geomLength), but these can not be used. For example, when using a filter like:
<Filter >
  <PropertyIsGreaterThan>
    <Function name="geomLength">
      <PropertyName>GEOM</Propertyname>
    </Function>
    <Literal>100</Literal>
  </PropertyIsGreaterThan>
</FIlter>
A serviceexception (parsing error) is returned.
The log says:
746133 [FINER] GMLFilterDocument - ENTRY Function Function org.xml.sax.helpers.AttributesImpl@anonymised.com
746133 [FINER] org.geotools.filter.FilterFilter - found start element: Function
746133 [FINEST] org.geotools.filter.FilterFilter - types: (xml): Function; (internal): -1
org.xml.sax.SAXException: Attempted to construct illegal filter - I dont understand the tag: Function. HINT: tags are case-sensitive!
  at org.geotools.filter.FilterFilter.startElement(FilterFilter.java:130)
  at org.geotools.gml.GMLFilterGeometry.startElement(GMLFilterGeometry.java:167)
  at org.geotools.gml.GMLFilterDocument.startElement(GMLFilterDocument.java:164)
  at org.xml.sax.helpers.ParserAdapter.startElement(Unknown Source)
  at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
It seems that support for filter functions is not implemented in ExpressionSAXParser. ExpressionDOMParser seems to have that, but this one is not used.
For more information on JIRA, see:
