[Geoserver-devel] [jira] Created: (GEOS-3691) Allow for extension blacklists
                 Key: GEOS-3691
                 URL: http://jira.codehaus.org/browse/GEOS-3691
             Project: GeoServer
          Issue Type: Improvement
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.0.1
From the mailing list:
Current we have, in various parts of the codebase, code
that looks up for specific extension point implementors
by using GeoServerExtensions.xxx
The mechanism makes it easy to add another extension
implementor, just declare it in the Spring context,
drop in a new jar, voilà.
But what if someone wants to disable an extension point
instead, say, disable a core output format or a core
store?
At the moment there is no way. We need an extension
point to break other extension points! Ha!
What about:
ExtensionFilter {
   boolean accept(String beanId, Object extension);
This should allow to plug into the Spring context
filters either filters that know about the bean id
the need to mask, something like:
{code:xml}
<bean id="hideCSV" class="org.geoserver.platform.ExtensionHider">
    <property name="beanId" value="CSVOutputFormat">
</bean>
{code}
that could be also provided as (both are useful):
{code:xml}
    <property name="beanClass"
              value="org.geoserver.wfs.response.CSVOutputFormat">
</bean>
{code}
But then again someone could also implement a filter that is
configuration aware and that can be used to hide extension
points that the administrator explicitly disabled from the
GUI (think of a panel allows to configure what output formats you want).
Opinions?
