Add tmpdir info to testing servlet parameters
Key: GEOS-3700
URL: http://jira.codehaus.org/browse/GEOS-3700
Project: GeoServer
Issue Type: Test
Affects Versions: 2.0.0
Reporter: David Winslow
Assignee: Andrea Aime
Attachments: tmpdir.patch
I'm working on adding some basic unit testing to the mapfish printing module. The mapfish servlet requires a valid tmpdir to start up properly (it stores generated PDFs on the filesystem.) It is bombing out when trying to read the 'javax.servlet.context.tempdir' property from the servlet context. The attached patch ensures that this property is set in the test environment.
