GeoServerLoader will fail with NPE if the "styles" subdirectory is missing
Key: GEOS-3707
URL: http://jira.codehaus.org/browse/GEOS-3707
Project: GeoServer
Issue Type: Bug
Components: Configuration
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 2.0.1
Following up a report from the users list I noticed the GeoServerLoader code will fail with an NPE if pointed to a data dir that does not have a styles subdirectory.
There is code such as:
{code}
File styles = resourceLoader.find( "styles" );
for ( File sf : list(styles,new SuffixFileFilter(".xml") ) ) {
{code}
which is not guarded against the possibility the dir is not there.
Wondering if the proper fix would be to use findOrCreate or just add a guard.
