[Geoserver-devel] [jira] Created: (GEOS-3708) Strange URL validation in Shapefile importer
                 Key: GEOS-3708
                 URL: http://jira.codehaus.org/browse/GEOS-3708
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0.x
            Reporter: Sebastian Benthall
            Assignee: Andrea Aime
         Attachments: PQUEPOS_Escenario_190.dbf, PQUEPOS_Escenario_190.shp, PQUEPOS_Escenario_190.shx
With a certain shapefile (attached) given a certain path in the Shapefile Store creation workflow, the URL field's validator seems to append an extra "file://" before the URL I enter, and then reports an error. Logs show a stack trace (also attached).
The original input to the URL field is:
{{file:data/Ejemplo_Puerto_Quepos-CRI/Esc190/PQUEPOS_Escenario_190.shp}}
That input is changed to the following when I click "Save":
{{file://file:data/Ejemplo_Puerto_Quepos-CRI/Esc190/PQUEPOS_Escenario_190.shp}}
The error reported in the page UI is:
{{Error creating data store, check the parameters. Error message: Shapefile not found:file:/file:data/Ejemplo_Puerto_Quepos-CRI/Esc190/PQUEPOS_Escenario_190.shp}}
Expected behavior: The data store should be created from the Shapefile. If the Shapefile is invalid, then I should get an error (hopefully an informative one about what's wrong with the Shapefile), but in this case the URL field should not change.
