Build failure in WMS GetMapKvpRequestReaderTest.testGroupInSLD when building in a path with spaces
Key: GEOS-3709
URL: http://jira.codehaus.org/browse/GEOS-3709
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.1.x
Reporter: Ben Caradoc-Davies
Assignee: Ben Caradoc-Davies
Priority: Blocker
Building in a path with spaces fails with:
{code}
Test set: org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 2.996 sec <<< FAILURE!
testGroupInSLD(org.geoserver.wms.kvp.GetMapKvpRequestReaderTest) Time elapsed: 0.004 sec <<< ERROR!
java.io.FileNotFoundException: /home/car605/geoserver/src%20with%20spaces/geoserver-trunk/src/wms/target/test-classes/org/geoserver/wms/kvp/BaseMapGroup.sld (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at java.io.FileInputStream.<init>(FileInputStream.java:66)
at sun.net.www.protocol.file.FileURLConnection.connect(FileURLConnection.java:70)
at org.vfny.geoserver.util.Requests.getInputStream(Requests.java:250)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:260)
at org.geoserver.wms.kvp.GetMapKvpRequestReaderTest.testGroupInSLD(GetMapKvpRequestReaderTest.java:428)
{code}
