[Geoserver-devel] [jira] Created: (GEOS-371) Add GeoTools DB2 plug-in
         Key: GEOS-371
         URL: http://jira.codehaus.org/browse/GEOS-371
     Project: GeoServer
        Type: New Feature
  Components: Configuration
    Versions: 1.3.0
Environment: All
    Reporter: David Adler
Assigned to: dblasby
     Fix For: 1.3.0
Attachments: db2-2.1.RC1.jar
The DB2 plug-in for GeoTools is now being shipped as part of the GeoTools 2.1RC1 release. It would be helpful if this could also be included with the corresponding GeoServer release.
David Blasby asked that the DB2 plug-in jar be attached here.
It is not possible to include the DB2 JDBC due to licensing and redistribution issues. Assuming that you have a DB2 installation to connect to, the JDBC driver is in the INTSTHOME/java subdirectory with names db2jcc.jar and db2jcc_license_cu.jar and need to be copied to the geoserver/WEB-INF/lib directory.
For more information on JIRA, see:
