app-schema build failure in FeatureChainingWfsTest.testDescribeFeatureType
Key: GEOS-3722
URL: http://jira.codehaus.org/browse/GEOS-3722
Project: GeoServer
Issue Type: Bug
Components: Application schema
Affects Versions: 2.0.x, 2.1.x
Reporter: Ben Caradoc-Davies
Assignee: Rini Angreani
Attachments: prevent-duplicate-feature-type-mappings.patch
Patch for GEOS-3553 has revealed an underlying problem in app-schema, causing build failure on some platforms. (Only me!)
The attached GeoTools patch causes fail-fast behaviour when duplicate mapping of feature types is attempted. It reveals that this occurs in both GT ans GS unit tests for app-schema.
