subfolder lookup of GeoServerDataDirectory
Key: GEOS-3725
URL: http://jira.codehaus.org/browse/GEOS-3725
Project: GeoServer
Issue Type: Bug
Components: Configuration, Global
Affects Versions: 2.0.0
Environment: Windows XP SP 3, Intel Core i5
Reporter: Frank
Assignee: Justin Deoliveira
Priority: Minor
There are two methods in org.geoserver.config.GeoServerDataDirectory, which are named semantically related, but do very different lookups.
These two methods are GeoServerDataDirectory.findOrCreateDataDir(String) and GeoServerDataDirectory.findDataDir(String).
Think of a configuration, where the base directory of a GeoServerDataDirectory is set to something like C:\myData (GEOSERVER_DATA_DIR=C:\myData ).
GeoServerDataDirectory.findOrCreateDataDir("coverages") would then create (or find) the file object "C:\myData\coverages".
A later call of GeoServerDataDirectory.findDataDir("coverages") would not find this file object, despite it has been successfully created.
I think it is because it searches for "C:\myData\data\coverages".
Additionally, a file stored in "C:\mydata\coverages\" cannot be retrieved by GeoServerDataDirectory.findDataFile("coverages\myFile.tif").
