changing the style in the OpenLayers preview is not reflected in getfeatureinfo requests
Key: GEOS-3745
URL: http://jira.codehaus.org/browse/GEOS-3745
Project: GeoServer
Issue Type: Bug
Components: UI
Affects Versions: 2.0.0
Environment: Linux webmapping.ems.psu.edu 2.6.9-89.0.18.EL #1 Wed Nov 25 06:03:55 EST 2009 i686 i686 i386 GNU/Linux
Reporter: Ian Turton
Assignee: Andrea Aime
Priority: Minor
If you have a broken style assigned to a featuretype (or just a zoom level filter) as default and also have a good style assigned to the layer you can test getFeatureInfo using the OpenLayers preview as changing the style in the menu doesn't affect the getFeatureInfo request. This is important as recent versions of GeoServer take the visibility of the point in to account when deciding to return a result.
