[Geoserver-devel] [jira] Created: (GEOS-3759) When rendering a WFS Layer as WMS, MultiPoint geometry is rendered as a single point
                 Key: GEOS-3759
                 URL: http://jira.codehaus.org/browse/GEOS-3759
             Project: GeoServer
          Issue Type: Bug
          Components: UI, WFS
    Affects Versions: 1.7.6
         Environment: Windows Server 2003 SE SP2
            Reporter: Ian Inglis
            Assignee: Andrea Aime
         Attachments: style.sld, wfs.xml
When doing a WMS rendering of a WFS layer that contains a MultiGeometry type with MultiPoints declared, the renderer only renders a single Point, despite how many points are declared in the MultiPoint object. The point rendered seems to be an aggregate of all of the points as it should not be rendering a point in the place it is.
