[Geoserver-devel] [jira] Created: (GEOS-377) WebShere problem
WebShere problem
         Key: GEOS-377
         URL: http://jira.codehaus.org/browse/GEOS-377
     Project: GeoServer
        Type: Improvement
    Versions: 1.3-rc1
Reporter: dblasby
Assigned to: dblasby
     Fix For: 1.3.1
This looks like its not a Geoserver issue, but I'd like to make sure we're compatible with Webshere.
If they want to commit a patch to all the .jsp (shudder), I'll apply it.
Email from ggb2g@anonymised.com:
I come back on the first issue first:
We finally identify the problem with a Websphere expert: it is a bug in WebSphere 5.1 (we tried also 5.2 and it is the same). The workaround is the following,
within *.jsp files whenever we have something similar to:
   else {
%> <html:link style="action"
                    forward="<%= forward %>"
                    titleKey='<%=forward+".short"%>'>
           <bean:message key='<%=forward+".label"%>'/>
         </html:link>
we have modified it this way:
   else {
       String sht = forward+".short";
   String lab = forward+".label";
                    titleKey='<%=sht %>'>
           <bean:message key='<%=lab %>'/>
         </html:link>
Ok, I know it is not very clean but at least the web admin works fine on websphere. I would like to recommend developers to find a workaround to integrate it in GeoServer or if you have any contact with IBM guys to report this bug, in our side we are trying to find someone but it is not that easy within such big organization!
Thx to everybody for your help and great work.
Gerald
Gerald Estadieu wrote:
Hi Alessio,
thanks for your answer. I have tried already to delete
the french file and use the english one but still
can't get the correct page...
I simply installed the default .war file so I do not
expect these properties files to be corrupted. I will
try to copy those from a windows installation.
Beside this the image generation is now working fine
without JAI for WMS.
Gerald
--- Alessio Fabiani <alessio.fabiani@anonymised.com> a
écrit :
I think that the problem is caused by the
Applicationresources_fr.properties
This file should contain all the messages in the
French language, if a
resource is missing you get an error like this.
Solutions:
1) change Applicationresources_fr.properties like
Applicationresources.properties if you need the
French version of
delete Applicationresources_fr.properties if you
want use only the
english(default) version
On 6/15/05, Gerald Estadieu <ggb2g@anonymised.com> wrote:
I am working for a utility company where we are
trying
to evaluate the possibility to use geoserver as a
geospatial server and integrates spatial data/map
in
our internal web applications(customer related,
maintenance) and make it as our main GIS.
Our environment currently is:
- Websphere 5.1 on RedHat
- Informix database as well as PostGIS
I deployed geoserver on websphere and it works, I
mean
the GetCapabilities for WFS and WMS are there and
seems valid.
However I still have a small issue:
when I connect to http://localhost/geoserver and
after
login I cannot see any
of the menu, I have instead the following message
(sorry it is based on
WebSphere in french).
[ServletException
in:/WEB-INF/pages/actionator.jsp]
/WEB-INF/pages/actionator.jsp(34,50) L'attribut
.short
n'a pas de valeur.'
(translation: the attribute .short has no value),
the
same problem for .label.
It is the same for all *tor.jsp pages.
Exactly the same problem occurs with
Geoserver1.3RC1
or Geoserver 1.2.
Any ideas on this? I search JIRA but could not
find
any answer.
I have not installed JAI lib so I understand that
WMS
cannot generate
bitmap files but it looks like even in 1.3 (I
tried
the mapbuilder demo
in data/mbdemo/) it does not generate a bitmap
image,
anything I miss
there (when trying to get the svg file I've got:
<ServiceException
code="">javax/media/jai/util/Range</ServiceException>
</ServiceExceptionReport>
)? Of course I have the GetCapabilities sending
back
xml file in
both WFS and WMS.
If I need to install JAI, any idea where I should
put
it on websphere?
Thx a lot,
Gerald
___________________________________________________________________________
Appel audio GRATUIT partout dans le monde avec le
nouveau Yahoo! Messenger
Téléchargez cette version sur
http://fr.messenger.yahoo.com
SF.Net email is sponsored by: Discover Easy Linux
Migration Strategies
from IBM. Find simple to follow Roadmaps,
straightforward articles,
informative Webcasts and more! Get everything you
need to get up to
speed, fast.
http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
Geoserver-users mailing list
For more information on JIRA, see:
