Logging filter will make Wicket file uploads fail
Key: GEOS-3770
URL: http://jira.codehaus.org/browse/GEOS-3770
Project: GeoServer
Issue Type: Bug
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0.1
This happens because the normal parameter parsing creates a Map whose values are String whilst the wrapper code expects Lists. So after calling into the base class parsing we need to adapt the results
