Build failure in wcs1_0 GetCoverageTest
Key: GEOS-3788
URL: http://jira.codehaus.org/browse/GEOS-3788
Project: GeoServer
Issue Type: Bug
Components: WCS
Affects Versions: 2.1.x
Reporter: Ben Caradoc-Davies
Assignee: Simone Giannecchini
Priority: Blocker
Looks like the GeoTools change by simonegiannecchini in r34844 to
modules/library/coverage/src/main/java/org/geotools/coverage/grid/GeneralGridGeometry.java
has changed the behaviour of GeoServer WCS causing a unit test to fail. Looks like only trunk is affected.
{code}
Test set: org.geoserver.wcs.GetCoverageTest
Tests run: 15, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.887 sec <<< FAILURE!
testDomainSubsetRxRy(org.geoserver.wcs.GetCoverageTest) Time elapsed: 0.034 sec <<< FAILURE!
junit.framework.AssertionFailedError: w expected:<181> but was:<180>
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.failNotEquals(Assert.java:280)
at junit.framework.Assert.assertEquals(Assert.java:64)
at junit.framework.Assert.assertEquals(Assert.java:198)
at org.geoserver.wcs.GetCoverageTest.testDomainSubsetRxRy(GetCoverageTest.java:133)
{code}
