[Geoserver-devel] [jira] Created: (GEOS-3790) Failure to load GDAL libraries when running as a service on windows
                 Key: GEOS-3790
                 URL: http://jira.codehaus.org/browse/GEOS-3790
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0.1
         Environment: Windows 2008 x64, Windows 2003 32bit, Windows XP 32bit SP3
            Reporter: Iván Sánchez Ortega
            Assignee: Andrea Aime
Once the GDAL binaries have been installed as per the user documentation, Geoserver will fail to load them properly. The GDAL image formats won't show up in the "new data store" web page.
However, this only happens when running Geoserver as a service (or running wrapper.exe manually). If launched through the start.bat script, Geoserver will load these libraries just OK, and the file formats will show up as usual.
Also, the logs will report failure to load the format factories, e.g.:
28 jan 12:53:22 DEBUG [gdal.erdasimg] - ErdasImgFormatFactory is not availaible.
This bug has been reported to occur on several systems (win2008 x64, win 2003, winxp sp3), and both on 2.0.0 and 2.0.1. See http://sourceforge.net/mailarchive/forum.php?thread_name=4B600F45.8020408%40opengeo.org&forum_name=geoserver-users
