[Geoserver-devel] [jira] Created: (GEOS-3799) GWC fails to seed EPSG:4236
                 Key: GEOS-3799
                 URL: http://jira.codehaus.org/browse/GEOS-3799
             Project: GeoServer
          Issue Type: Bug
          Components: GWC
    Affects Versions: 2.0.1
         Environment: Ubuntu karmic server (512MB, 2.0GHz), Sun Java 6, Tomcat 6, Geoserver 2.0.1.
            Reporter: James Nicolson
            Assignee: Andrea Aime
         Attachments: gwc-imagepyamid-failure.txt
When trying to seed more than 3 zoom layers of an imagepyramid in EPSG:4236 PNG/JPEG, GWC hangs (i.e. stops generating anymore tiles), but CPU usage and memory usage by jsvc remains the same. After about 10 minutes it stops seeding and exits due to a WMS timeout exception (log file attached). Using the web UI it appears that after 40 tiles the caching stops, no matter how many zoom layers are selected for caching. However, after attempting to recreate the same problem inside a virtual machine with 1GB ram, the caching process ends successfully.
In addition, the same imagepyramid was successfully cached for 12 zoom layers in EPSG:900913.
