Postgis failure creating new FeatureType
Key: GEOS-380
URL: http://jira.codehaus.org/browse/GEOS-380
Project: GeoServer
Type: Bug
Components: PostGIS, Configuration
Versions: 1.3-rc2
Environment: Postgres 8.0.3, PostGIS unknown, GeoServer build from svn
Reporter: Jody Garnett
Assigned to: dblasby
Priority: Minor
Fix For: 1.3-rc3
We found and 8.03 postgres capable of hosting your dump.
However we ran into a pretty major error when adding a new feature type.
A real geoserver error actually.
We were able to add the datastore - called turtle.
When adding a new featureType we were able to get the list and select the "turtle:finalroads" entry.
However the answer we got back was this:
HTTP ERROR: 500 An+SQL+exception+occurred%3A+ERROR%3A+permission+denied+for+relation+geometry%5Fcolumns%0A
RequestURI=/geoserver/config/data/typeNewSubmit.do
Powered by Jetty://
That is a pretty serious error, it should of returned to the last screen Create New FeatureType and listed the error in the usual fashion. Of course we should of got this error when we set up the featureStore for the first time.
For more information on JIRA, see:
