[Geoserver-devel] [jira] Created: (GEOS-3805) java.lang.IllegalStateException: Subject type not loaded yet
                 Key: GEOS-3805
                 URL: http://jira.codehaus.org/browse/GEOS-3805
             Project: GeoServer
          Issue Type: Bug
          Components: Application schema
    Affects Versions: 2.0.x
            Reporter: Florence Tan
            Assignee: Andrea Aime
As GeoServer only allows one FeatureType of same type per instance, in order to achieve more than one silimar type, a new schema been created to have the similar type with different element name:
1) Created a new schema under a new profiles directory
(profiles/Borehole.xsd)
<schema xmlns="http://www.w3.org/2001/XMLSchema&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; targetNamespace="urn:cgi:xmlns:CGI:GeoSciML:2.0">
  <annotation>
    <documentation>Profile wrapper for Borehole</documentation>
  </annotation>
  <import namespace="http://www.opengis.net/gml&quot; schemaLocation="http://schemas.opengis.net/gml/3.1.1/base/gml.xsd&quot;/&gt;
  <import namespace="http://www.opengis.net/sampling/1.0&quot; schemaLocation="http://schemas.opengis.net/sampling/1.0.0/sampling.xsd&quot;/&gt;
  <include schemaLocation="http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd&quot;/&gt;
  <element name="BoreholeHeader" type="gsml:BoreholeType" substitutionGroup="sa:SamplingCurve"/>
</schema>
2) Have the geoserver config file pointing to the new schema file :
<targetTypes>
<FeatureType>
<schemaUri>../profiles/Borehole.xsd</schemaUri>
</FeatureType>
</targetTypes>
3) Running the config file will receive the following java exception :
<ows:ExceptionReport version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:ows="http://www.opengis.net/ows&quot;&gt;
- <ows:Exception exceptionCode="NoApplicableCode">
  <ows:ExceptionText>java.lang.IllegalStateException: Subject type not loaded yet Subject type not loaded yet</ows:ExceptionText>
  </ows:Exception>
  </ows:ExceptionReport>
