REST API using JSON output errors on default configuration
Key: GEOS-3817
URL: http://jira.codehaus.org/browse/GEOS-3817
Project: GeoServer
Issue Type: Bug
Components: REST
Affects Versions: 2.0.x
Reporter: David Winslow
Assignee: Andrea Aime
It seems that requesting JSON for any object whose encoding would include a NaN value throws an uncaught error. An example of this is available using the GeoServer release dataset, with the restconfig extension enabled:
$ curl http://admin:geoserver@anonymised.com:8080/geoserver/rest/workspaces/nurc/coveragestores/mosaic/coverages/mosaic.json -D -
HTTP/1.1 200 OK
Date: Thu, 18 Feb 2010 20:23:08 GMT
Server: Noelios-Restlet-Engine/1.0..8
Content-Type: application/json
Content-Length: 0
The log shows an exception being thrown in Jettison; presumably a 500 should be shown to the REST client as well.
This coverage has InputImageThresholdValue set to NaN. If I set it to 0, the JSON output contains a JSON object as expected.
