Add GetStyle PutStyle
Key: GEOS-382
URL: http://jira.codehaus.org/browse/GEOS-382
Project: GeoServer
Type: Improvement
Components: WMS
Reporter: dblasby
Assigned to: Gabriel Roldán
Fix For: 1.3.1
The SLD Specification describes the GetStyle and PutStyle operations (page 74).
We should add these - they could form the basis of an "external" SLD editor (hurray for that) plus they could also be used for communicating configuration to udig and mapserver.
udig could use it to get an already existing SLD for the WFS rendering and also so the user can create there own in udig and upload it to the server.
When we do this, we should look at re-doing the styling system so its a bit more ridgid (i.e. what styles go with what layers, the actual allowed content in the styles, etc...).
NOTE: the get/put operations are probably not quite what you might expect. They also imply that you can create new datasets (ie. user layers). We'll probably want to start with something simple, then carry on to something a bit more complex.
For more information on JIRA, see:
