[Geoserver-devel] [jira] Created: (GEOS-383) change Default speed Strategy
         Key: GEOS-383
         URL: http://jira.codehaus.org/browse/GEOS-383
     Project: GeoServer
        Type: Improvement
Reporter: dblasby
Assigned to: dblasby
     Fix For: 1.3.1
I'd like to see the default speed strategy (ie. start sending the response out as soon as you generate anything to send) to a slightly different version:
1. buffer the first (say) 25k
2. start streaming after the 25k
The reason for this is because most error occur right at the start of a response (ie. in the first few kb it sends out). Unfortunately, with the speed strategy (the current default) you will not get proper error messages (because you've already sent out data and cannot "unsend" it and replace it with a service exception).
The other main strategy is "full buffer" which will buffer the entire response. When the response is finished (with no errors), it will send the reponse to the user. If there was an error (at any stage) it can "unsend" the reponse because it hasnt actually sent anything. This works quite well since all error are properly reported.
The new version I'm proposing has the best of both worlds -- fast streaming output and the ability to report errors (in most cases). This makes a sensable default.
For more information on JIRA, see:
