[Geoserver-devel] [jira] Created: (GEOS-3830) UpdateSequence is not getting updated
                 Key: GEOS-3830
                 URL: http://jira.codehaus.org/browse/GEOS-3830
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.0.1
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.0.2
Every time we change the service configuration or the catalog the update sequence number should go up.
Ideally, up once per interaction with the GUI, but even if it goes up faster it's not a problem, the functionatliy of the update sequence (to let clients know the capabilities documents have changed) will be preserved
