Feature properties are not updated when recreating layer
Key: GEOS-3834
URL: http://jira.codehaus.org/browse/GEOS-3834
Project: GeoServer
Issue Type: Bug
Components: PostGIS
Affects Versions: 2.0.0
Reporter: Peter Becker
Assignee: Andrea Aime
Priority: Minor
We are currently experiencing an issue where GeoServer doesn't seem to notice changes in our PostGIS database. Our current work involves a bit of playing around with data in the form:
* add column to database table
* fill column with some derived data
* recreate layer for the table
* use style showing the added data
* profit
The problem we encounter is that when recreating the layer GeoServer does not seem to recognize the new columns in the database. They will not appear as feature properties unless we restart the Tomcat instance GeoServer runs in. That means we need to restart the server rather often since we are currently in a phase of experimentation with the data.
