Exception when trying to render dashed lines
Key: GEOS-3835
URL: http://jira.codehaus.org/browse/GEOS-3835
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.0.0
Reporter: Peter Becker
Assignee: Andrea Aime
Priority: Minor
I'm trying to render a style using a dashed line, but all I get is this:
{noformat}
java.lang.NumberFormatException: empty String
at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1012)
at java.lang.Float.parseFloat(Float.java:439)
at org.geotools.styling.SLDParser.parseStroke(SLDParser.java:1760)
at org.geotools.styling.SLDParser.parseLineSymbolizer(SLDParser.java:893)
at org.geotools.styling.SLDParser.parseRule(SLDParser.java:826)
at org.geotools.styling.SLDParser.parseFeatureTypeStyle(SLDParser.java:756)
at org.geotools.styling.SLDParser.parseStyle(SLDParser.java:712)
at org.geotools.styling.SLDParser.readDOM(SLDParser.java:319)
at org.geotools.styling.SLDParser.readXML(SLDParser.java:295)
at org.geoserver.catalog.ResourcePool.getStyle(ResourcePool.java:871)
at org.geoserver.catalog.impl.StyleInfoImpl.getStyle(StyleInfoImpl.java:60)
at sun.reflect.GeneratedMethodAccessor167.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:113)
at $Proxy9.getStyle(Unknown Source)
at org.geoserver.wms.WMS.getStyleByName(WMS.java:74)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.parseStyles(GetMapKvpRequestReader.java:1202)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:277)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:70)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1094)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:437)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:206)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at sun.reflect.GeneratedMethodAccessor127.invoke(Unknown Source)
at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:269)
at java.security.AccessController.doPrivileged(Native Method)
at javax.security.auth.Subject.doAsPrivileged(Subject.java:537)
{noformat}
Here is an excerpt of the SLD causing this (I can provide a full version if necessary):
{noformat}
<sld:Rule>
<ogc:Filter>
<ogc:PropertyIsEqualTo>
<ogc:PropertyName>water_type</ogc:PropertyName>
<ogc:Literal>UE_NOOSA</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
<sld:LineSymbolizer>
<sld:Stroke>
<sld:CssParameter name="stroke">
<ogc:Literal>#000044</ogc:Literal>
</sld:CssParameter>
<sld:CssParameter name="stroke-width">
<ogc:Literal>3</ogc:Literal>
</sld:CssParameter>
<sld:CssParameter name="stroke-offset">
<ogc:Literal>0</ogc:Literal>
</sld:CssParameter>
<sld:CssParameter name="stroke-dasharray">
<ogc:Literal>2.0 1.0 4.0 1.0</ogc:Literal>
</sld:CssParameter>
</sld:Stroke>
</sld:LineSymbolizer>
</sld:Rule>
{noformat}
The exception seems to be triggered by the presence of the stroke-dasharray CSS parameter, if I remove that everything render fine (but not dashed).
