[Geoserver-devel] [jira] Created: (GEOS-3837) kmlplacemark setting breaking raster map generation
                 Key: GEOS-3837
                 URL: http://jira.codehaus.org/browse/GEOS-3837
             Project: GeoServer
          Issue Type: Bug
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 2.0.2
The way kmlplacemark is handled in the current code base is way undesirable.
First, there is code dealing with kmlplacemark in DefaultRasterMapProducer. It is way off place, that manipulation
should occur in the KMZMapProducer instead: a raster map producer
should know nothing about kml. (I guess I did not review the
patch that introduced kmlplacemark, my bad).
Secondly, the code tries to strip off text and point symbolizers by setting them to null.
This breaks big time all symbolizer visitors, and in particular the meta buffer one.
Rules are simply not supposed to contain null symbolizers, the code that filters out
point and text symbolizers has to be fixed accordingly
