[Geoserver-devel] [jira] Created: (GEOS-3840) validation error when POSTing SLD
                 Key: GEOS-3840
                 URL: http://jira.codehaus.org/browse/GEOS-3840
             Project: GeoServer
          Issue Type: Bug
          Components: REST
    Affects Versions: 2.0.1
         Environment: WinXp, jdk1.6.0_18
            Reporter: Anton
            Assignee: Andrea Aime
When uploading a sld file using the REST API, the the proccess fails when the SLD file has an OnlineResource (for example, try uploading a file with the identical contents of the 'grass' sld file).
The wrapper.log file has the following:
INFO | jvm 1 | 2010/03/03 15:38:15 | 03 mar 15:38:15 WARN [geotools.styling] - can't parse grass_fill.png as a java resource present in the classpath
INFO | jvm 1 | 2010/03/03 15:38:15 | 82128262 [btpool0-1] ERROR org.mortbay.log - Nested in org.springframework.web.util.NestedServletException: Handler processing failed; nested exception is java.lang.Error: SOMEONE CODED THE X LINK NAMESPACE WRONG!!:
INFO | jvm 1 | 2010/03/03 15:38:15 | java.lang.Error: SOMEONE CODED THE X LINK NAMESPACE WRONG!!
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:536)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.ExternalGraphicImpl.accept(ExternalGraphicImpl.java:127)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:680)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.GraphicImpl.accept(GraphicImpl.java:367)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:567)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.FillImpl.accept(FillImpl.java:199)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:517)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.PolygonSymbolizerImpl.accept(PolygonSymbolizerImpl.java:138)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:620)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.RuleImpl.accept(RuleImpl.java:309)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:939)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:904)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:738)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.visit(SLDTransformer.java:710)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.StyledLayerDescriptorImpl.accept(StyledLayerDescriptorImpl.java:194)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.encode(SLDTransformer.java:1061)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.styling.SLDTransformer$SLDTranslator.encode(SLDTransformer.java:1070)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.catalog.rest.SLDFormat.write(SLDFormat.java:54)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.rest.format.StreamDataFormat$1.write(StreamDataFormat.java:48)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.catalog.rest.StyleResource.handleObjectPost(StyleResource.java:151)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:115)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.restlet.Finder.handle(Finder.java:296)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.restlet.Filter.doHandle(Filter.java:105)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.restlet.Filter.handle(Filter.java:134)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.restlet.Router.handle(Router.java:444)
INFO | jvm 1 | 2010/03/03 15:38:15 | at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
INFO | jvm 1 | 2010/03/03 15:38:15 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
INFO | jvm 1 | 2010/03/03 15:38:15 | at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.Server.handle(Server.java:324)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:842)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:648)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:205)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
INFO | jvm 1 | 2010/03/03 15:38:15 | at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
INFO | jvm 1 | 2010/03/03 15:38:15 | 82128340 [btpool0-1] ERROR org.mortbay.log - /geoserver/rest/styles.sld
