[Geoserver-devel] [jira] Created: (GEOS-3846) ServiceInfo XStream deserialization may lead to null pointer exceptions
                 Key: GEOS-3846
                 URL: http://jira.codehaus.org/browse/GEOS-3846
             Project: GeoServer
          Issue Type: Bug
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 2.0.2
Looking into why WPS capabilities generation would throw an NPE after the first GS restart with WPS enabled I found the keywords array in the WPSServiceImpl to be null.
Investigation shows that XStream is not calling the default constructor when doing deserialization (http://xstream.codehaus.org/faq.html#Serialization_no_ctor_running) meaning the collections are not getting initialized.
I know XStreamServiceLoader.initialize is meant to be used for this purpose, but looking around I see that only the versions array is taken care of, meaning other services are just as vulnerable to this failure should someone remove the <service>.xml file and restart GeoServer.
I think we can fix this by having XStreamServiceLoader.initialize take care of initializing all collections in ServiceInfoImpl, and recommend subclasses to call back to the parent implementation before adding their own specific bits.
Opinions?
