[Geoserver-devel] [jira] Created: (GEOS-3850) Some rasters show No Data as black areas (regression from 1.7.6)
                 Key: GEOS-3850
                 URL: http://jira.codehaus.org/browse/GEOS-3850
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.0.1
         Environment: SDE 9.2 (using 9.3 jars), Oracle 10.2, tomcat 5.5.9, Linux Debian Sarge
            Reporter: Aleda Freeman
            Assignee: Andrea Aime
GeoServer 1.7.6 fixed black No Data areas, but I find that for some rasters this problem has come back in 2.01. (using nightly from 2/9/2010). Below is name of image, type of image, whether arcy has a useful copy or clip, and links to screenshots.
type: 3-band continuous, unsigned integer 8 bit, no colormap
arcy: no
screenshot GeoServer 1.7.6: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coloroq1_gs_176.jpg
screenshot GeoServer 2.0.1: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coloroq1_gs_201.jpg
arcy: no
screenshot GeoServer 1.7.6: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coq2001_gs_176.jpg
screenshot GeoServer 2.0.1: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coq2001_gs_201.jpg
arcy: SDE.IMG_COQ2008_30CM_CLIP_HULL (No Data section exists in the upper right)
screenshot GeoServer 1.7.6: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coq2008_30cm_gs_176.jpg
screenshot GeoServer 2.0.1: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coq2008_30cm_gs_201.jpg
arcy: no
screenshot GeoServer 1.7.6: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coq2008_15cm_gs_176.jpg
screenshot GeoServer 2.0.1: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coq2008_15cm_gs_201.jpg
arcy: no
type: 4-band continuous, unsigned integer 8 bit, no colormap
arcy: no
screenshot GeoServer 1.7.6: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coq2005_gs_176.jpg
screenshot GeoServer 2.0.1: http://maps.massgis.state.ma.us/temp/raster_black_no_data/img_coq2005_gs_201.jpg
type: 1-band discrete unsigned integer 8 bit, COLORMAPPED
arcy: yes SDE.CCAP_MA_01_RD
screenshot GeoServer 1.7.6: http://maps.massgis.state.ma.us/temp/raster_black_no_data/ccap_ma_01_rd_gs_176.jpg
screenshot GeoServer 2.0.1: http://maps.massgis.state.ma.us/temp/raster_black_no_data/ccap_ma_01_rd_gs_201.jpg
arcy: yes SDE.CCAP_MA_96_RD
screenshot GeoServer 1.7.6: http://maps.massgis.state.ma.us/temp/raster_black_no_data/ccap_ma_96_rd_gs_176.jpg
screenshot GeoServer 2.0.1: http://maps.massgis.state.ma.us/temp/raster_black_no_data/ccap_ma_96_rd_gs_201.jpg
name: any NOAA chart - for example, NOAA.13006_1
arcy: yes, SDE.NOAA.13006_1
screenshot GeoServer 1.7.6: http://maps.massgis.state.ma.us/temp/raster_black_no_data/noaa_13006_gs_176.jpg
screenshot GeoServer 2.0.1: http://maps.massgis.state.ma.us/temp/raster_black_no_data/noaa_13006_gs_201.jpg
Gabriel thinks this is easy to fix, and it's blocking me from upgrading from 1.7.6 to 2.0.1 because it's so disruptive. I can try to add more clips to arcy if that's helpful but since Gabriel got this to work before I'm hoping he already knows what needs to be done.
I wonder now if using the SDE 9.3 jars have something to do with it - but we need to use the jars to get the raster drawing speedup.
