Null Pointer error on <Abstract /> short tag in SLD
Key: GEOS-3870
URL: http://jira.codehaus.org/browse/GEOS-3870
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 2.0.1
Environment: Debian lenny 64
Reporter: Milo van der Linden
Assignee: Justin Deoliveira
Fix For: 2.0.2
Using the syntax:
<Rule>
<Abstract/>
<ogc:Filter>
<ogc:PropertyIsEqualTo>
Validates through the SLD validator, Causes a nullPointer exception when rendering while:
<Rule>
<Abstract></Abstract>
<ogc:Filter>
Works fine.
It looks as if the short tag <.. /> syntax is causing issues?
