[Geoserver-devel] [jira] Created: (GEOS-3874) Style Editor Warnings with RasterSymbolizer
                 Key: GEOS-3874
                 URL: http://jira.codehaus.org/browse/GEOS-3874
             Project: GeoServer
          Issue Type: Bug
         Environment: Linux Ubuntu (Karmic Koala), Geoserver 2.0.1
            Reporter: Piero Campalani
            Assignee: Andrea Aime
            Priority: Trivial
In the Style Editor, when VALIDATING a RasterSymbolizer with a ColorMap specifying the TYPE and/or EXTENDED values, a warning is returned (which should not be returned).
That is:
* org.xml.sax.SAXParseException: cvc-complex-type.3.2.2: Attribute 'type' is not allowed to appear in element 'ColorMap'.
* org.xml.sax.SAXParseException: cvc-complex-type.3.2.2: Attribute 'extended' is not allowed to appear in element 'ColorMap'.
if you write something like: <ColorMap type="<type>" extended="<T/F>">
(where <type>={ramp(default), intervals, values} and <extended>={true, false}).
