[Geoserver-devel] [jira] Created: (GEOS-3884) generic GetFeatureInfo template location
                 Key: GEOS-3884
                 URL: http://jira.codehaus.org/browse/GEOS-3884
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.0.0
         Environment: Ubuntu 9.10
            Reporter: Tim Schaub
            Assignee: Andrea Aime
            Priority: Minor
I've got a 2.0-SNAPSHOT - apologies for not knowing more about the version.
When I put a content.ftl in data_dir/workspaces/myws/mystore/mylayer/, I see the result getting rendered with GetFeatureInfo requests. If I try to put the same template instead in data_dir/workspaces or at the root of data_dir, I get the default template rendered for GetFeatureInfo responses.
The docs http://docs.geoserver.org/stable/en/user/tutorials/GetFeatureInfo/index.html and http://docs.geoserver.org/stable/en/user/tutorials/freemarker.html#template-lookup refer to the old featureTypes directory. I'm guessing the same should apply for the workspaces directory, but I am unable to get a generic template to be used in GetFeatureInfo responses.
