Rectangular graphics in tiled fills are being rendered (squished) to be square
Key: GEOS-3888
URL: http://jira.codehaus.org/browse/GEOS-3888
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 2.0.1
Environment: 2.0.1 (Windows service)
Reporter: Mike Pumphrey
Assignee: Andrea Aime
Priority: Minor
Fix For: 2.0.2
Attachments: badrender.png, colorblocks.png
The SLD spec does not give any limitation on the size/shape of a graphic used in a graphic fill (the <ExternalGraphic> element. As far as I can tell, the <Size> element refers to the height of the graphic, and the width is scaled accordingly.
Except that GeoServer appears to be setting both the width and the height to be the <Size> value, squishing a rectangular graphic to be square.
Attached are the graphic and the output. Please let me know if you need anything else.
