[Geoserver-devel] [jira] Created: (GEOS-39) Test and document the restriction filter.
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-39
Here is an overview of the issue:
        Key: GEOS-39
    Summary: Test and document the restriction filter.
       Type: Task
     Status: Open
   Priority: Minor
Original Estimate: 45 minutes
Time Spent: Unknown
  Remaining: 45 minutes
    Project: GeoServer
Components:
             Configuration
   Fix Fors:
             1.1.1
   Versions:
             1.1.0
   Assignee: Chris Holmes
   Reporter: Chris Holmes
    Created: Tue, 6 Jan 2004 9:17 PM
    Updated: Tue, 6 Jan 2004 9:17 PM
Description:
We have code that reads in a filter for a featureType and makes it as a restriction for requests. This has not been tested with datasources other than arcSDE, however, and is not yet documented at all. The documentation should go into the FeatureType control section of advanced.htm
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
