keywords missing from rest configuration for FeatureType
Key: GEOS-3911
URL: http://jira.codehaus.org/browse/GEOS-3911
Project: GeoServer
Issue Type: Bug
Components: REST
Affects Versions: 2.0.1
Environment: not applicable
Reporter: Tara Athan
Assignee: Andrea Aime
Priority: Minor
the FeatureType class does not contain properties to hold the keywords. This has a major effect that using the updateFeatureTypes method of the class FeatureTypeConfigClient will clear all keywords from the FeatureType. In addition, the functionality to add, delete or change keywords is missing.
It appears that the same also applies to FeatureType metadata, and a number of xml elements that appear in the Coverage Rest output.
The way this code is set up, if any new elements are added to the xml that were not there when the code was written, this problem will come up. I would propose that the code be set up to keep all unexpected xml elements the same. That way an update would not misconfigure the record. Then the extra functionality to update new elements could be added as convenient.
