Pyramide
Key: GEOS-3923
URL: http://jira.codehaus.org/browse/GEOS-3923
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.0.1
Environment: Windows All versions
Reporter: mike
Assignee: Andrea Aime
Priority: Blocker
Folowing the toturial on:
http://docs.geoserver.org/2.0.x/en/user/tutorials/imagepyramid/imagepyramid.html
I cant get to work rhe imagePyramide on the curent nightly buid. Date 16.4.2010.
I always get the error:
Could not list layers for this store, an error occurred retrieving them: This plugin accepts only File, URL and String pointing to a file
In tuturialit says:
When clicking save the store will look into the directory, recognize a gdal_retile generated structure and perform some background operations:
* move all tiff files in the root to a newly create directory 0
* create an image mosaic in all sub-directories (shapefile index plus property file)
* create the root property file describing the whole pyramid structure
But its not working. Plese help i need to make a coverage piramide on the geoserver engine.
