REST not fault tolerant when writing out SLD files
Key: GEOS-3933
URL: http://jira.codehaus.org/browse/GEOS-3933
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.0.1
Reporter: Justin Deoliveira
Assignee: Justin Deoliveira
When an error occurs during the encoding of an SLD document the system is left with a half written file on disk. It should use the same approach that the configuration writer uses in which the file is first written to a temp file and in the result of no error then moved to the final final.
