GeoServer WMS as FPS: non default timeout in the WMS config panel
Key: GEOS-3936
URL: http://jira.codehaus.org/browse/GEOS-3936
Project: GeoServer
Issue Type: Improvement
Components: WMS
Affects Versions: 2.0.1
Reporter: doomoo
Assignee: Andrea Aime
When the Remote WFS specified in an SLD document has to create a GetFeature-Response with too much data I get an exception:
org.vfny.geoserver.wms.WmsException: Rendering process failed
Error rendering feature
Could not aquire feature:java.net.SocketTimeoutException: Read timed out
Read timed out
When I insert the same Remote WFS in the WFSDataStore I can manage a request, but only if I enter a sufficient "Connection and read timeout"-value.
It would be nice to give the user the ability to increase the timeout-value without using the WFSDataStore.
