[Geoserver-devel] [jira] Created: (GEOS-3975) Native SRS field should be text instead of an input field
                 Key: GEOS-3975
                 URL: http://jira.codehaus.org/browse/GEOS-3975
             Project: GeoServer
          Issue Type: Bug
          Components: UI
    Affects Versions: 2.0.1
            Reporter: Tom MacWright
            Assignee: Andrea Aime
There's no indication that the Native SRS field in the layer form of the GeoServer UI is never editable, and it makes the user expect that one can reproject between the two. Also, behavior between an 'undefined' Native SRS and a Declared SRS is incredibly unclear. Essentially that area of the interface is incredibly confusing and could use stronger documentation and a better sense of user experience.
