[Geoserver-devel] [jira] Created: (GEOS-3982) Intermittent build failure in NewUserpageTest
                 Key: GEOS-3982
                 URL: http://jira.codehaus.org/browse/GEOS-3982
             Project: GeoServer
          Issue Type: Bug
          Components: Security
    Affects Versions: 2.0.x
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
NewUserPageTest fails from time to time. Race condition? Known to affect 2.0.x, but I think I saw it on trunk as well.
Here is one example:
{code}
Tests in error:
  testFill(org.geoserver.web.security.user.NewUserPageTest)
{code}
{code}
Test set: org.geoserver.web.security.user.NewUserPageTest
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 8.306 sec <<< FAILURE!
testFill(org.geoserver.web.security.user.NewUserPageTest) Time elapsed: 1.768 sec <<< ERROR!
org.acegisecurity.userdetails.UsernameNotFoundException: Could not find user: user
  at org.geoserver.security.GeoserverUserDao.loadUserByUsername(GeoserverUserDao.java:69)
  at org.geoserver.web.security.user.NewUserPageTest.testFill(NewUserPageTest.java:44)
{code}
     [ http://jira.codehaus.org/browse/GEOS-3982?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Ben Caradoc-Davies reopened GEOS-3982:
      Assignee: Ben Caradoc-Davies (was: Andrea Aime)
Still failing on trunk.
Intermittent build failure in NewUserPageTest
                Key: GEOS-3982
            Project: GeoServer
         Issue Type: Bug
   Affects Versions: 2.0.x, 2.1.x
            Fix For: 2.0.3, 2.0.x, 2.1.x
        Attachments: GEOS-3982.NewUserPageTest.patch
{code}
Tests in error:
{code}
{code}
{code}
