JDBC SQLException when publishing Oracle Spatial layer via Oracle extension JNDI datasource
Key: GEOS-3986
URL: http://jira.codehaus.org/browse/GEOS-3986
Project: GeoServer
Issue Type: Bug
Components: Oracle
Affects Versions: 2.0.2
Environment: Linux 64 bit RedHat, Apache Tomcat 6.0.20, Java 1.6.0, Oracle 10g, Oracle Java 6 JDBC driver (ojdbc6.jar)
Reporter: Micah Wengren
Assignee: Andrea Aime
I get the following stack trace when trying to publish a layer in Geoserver 2.0.2 using Oracle JNDI connection pool datastore. The data store configuration is successful, and I've configured the same layer from the same database in identical Tomcat instance using Geoserver 2.0 previously without any issues. When I go to the layer publish GUI steps, I am able to see all of the database tables in the schema, but clicking on the 'compute from data' link under Bounding Boxes causes the following stack trace dump.
Identical setup works with GeoServer 2.0 deployed alongside 2.0.2 in the same Tomcat instance..... is it possible to deploy 2 GeoServer instances within the same Tomcat?
java.lang.RuntimeException: java.io.IOException: Error occured calculating bounds
at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:484)
at org.geotools.jdbc.JDBCFeatureStore.getBoundsInternal(JDBCFeatureStore.java:178)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:366)
at org.geotools.data.store.ContentFeatureSource.getBounds(ContentFeatureSource.java:338)
at org.vfny.geoserver.global.GeoServerFeatureSource.getBounds(GeoServerFeatureSource.java:526)
at org.geoserver.catalog.CatalogBuilder.getNativeBounds(CatalogBuilder.java:460)
at org.geoserver.web.data.resource.BasicResourceConfig$1.onSubmit(BasicResourceConfig.java:123)
at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:94)
at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:128)
at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:163)
at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:297)
at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:104)
at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:91)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1239)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:532)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:356)
at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:145)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:271)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:567)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:769)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:698)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:891)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.io.IOException: Error occured calculating bounds
at org.geotools.jdbc.JDBCDataStore.getBounds(JDBCDataStore.java:1053)
at org.geotools.jdbc.JDBCFeatureSource.getBoundsInternal(JDBCFeatureSource.java:477)
... 79 more
Caused by: java.sql.SQLException: Could not obtain native oracle connection for class org.apache.tomcat.dbcp.dbcp.PoolableConnection
at org.geotools.data.oracle.OracleDialect.unwrapConnection(OracleDialect.java:471)
at org.geotools.data.oracle.OracleDialect.readGeometry(OracleDialect.java:415)
at org.geotools.data.oracle.OracleDialect.readGeometry(OracleDialect.java:405)
at org.geotools.data.oracle.OracleDialect.decodeGeometryEnvelope(OracleDialect.java:352)
at org.geotools.jdbc.JDBCDataStore.getBounds(JDBCDataStore.java:1013)
... 80 more
