GeoServerUserDao introduces non obvious dependency loop
Key: GEOS-3991
URL: http://jira.codehaus.org/browse/GEOS-3991
Project: GeoServer
Issue Type: Bug
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0.3
GeoServerUserDao depends on GeoServer which depends on the catalog, which is the secure catalog, which in turn depends on the security manage, which uses the user dao.
In a normal startup this does not show but when adding extra bits in the spring configuration (in this case, the ftp server module) it becomes evident.
The loop can be broken by having the dao grab GeoSEver using GeoServerExtensions when the first authentication is actually required.
