[Geoserver-devel] [jira] Created: (GEOS-4008) Missing SLD in release configuration
                 Key: GEOS-4008
                 URL: http://jira.codehaus.org/browse/GEOS-4008
             Project: GeoServer
          Issue Type: Sub-task
    Affects Versions: 2.0.2
            Reporter: David Winslow
            Assignee: Justin Deoliveira
            Priority: Trivial
             Fix For: 2.0.3
The release dataset contains a configuration for 'concat.sld' but not the actual SLD file. The style isn't listed for any layers, so it's not a big problem, but we may as well delete the style or provide the SLD.
Justin, SVN says you added concat.xml, so do you have the SLD floating around?
