[Geoserver-devel] [jira] Created: (GEOS-4016) Some connection parameters of PostGIS DB not set with RESTful configuration
                 Key: GEOS-4016
                 URL: http://jira.codehaus.org/browse/GEOS-4016
             Project: GeoServer
          Issue Type: Bug
          Components: REST
    Affects Versions: 2.0.1
         Environment: Ubuntu Lucid on DELL Studio XPS.
            Reporter: Piero Campalani
            Assignee: Andrea Aime
         Attachments: BabylonDataStore.xml
Whether I upload a PostGIS database into Geoserver via REST configuration (I'm using cURL to send requests via shell commands), some connection paramters ('max/min connections', 'fetch size', 'connection timeout', 'validate connections', 'lloose bbox', 'prepared statements', 'max open prepared statements') are not set on their default values just like when you upload a PostGIS DB manually via web graphic interface (and I don't know how to change their value via REST).
