Update maven docs for GeoServer 2.0
Key: GEOS-4024
URL: http://jira.codehaus.org/browse/GEOS-4024
Project: GeoServer
Issue Type: Improvement
Components: Documentation
Affects Versions: 2.0.2
Reporter: Jody Garnett
Assignee: Andrea Aime
I wasted a bit of time sorting out how mvn jetty:run can be made to work:
- jetty plugin needs a change to the settings.xml in order to be found by modern versions of maven
- documentation asks you to run from web/ directory; this actually needs to be the web/app directory
- also noticed the profiles section was empty
The attach patch addresses these issues.
