[Geoserver-devel] [jira] Created: (GEOS-4035) Some GWC tests fail for clean install Rev 14530
                 Key: GEOS-4035
                 URL: http://jira.codehaus.org/browse/GEOS-4035
             Project: GeoServer
          Issue Type: Bug
          Components: GWC
    Affects Versions: 2.0.x
         Environment: mvn --version
Maven version: 2.0.9
Java version: 1.6.0_17
OS name: "linux" version: "2.6.32.14-127.fc12.x86_64" arch: "amd64" Family: "unix"
            Reporter: Geoff Clitheroe
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: org.geoserver.gwc.GWCIntegrationTest.txt, TEST-org.geoserver.gwc.GWCCatalogListenerTest.xml, TEST-org.geoserver.gwc.GWCIntegrationTest.xml
Tests fail for mvn clean install.
TEST-org.geoserver.gwc.GWCCatalogListenerTest.xml: <system-out>29 Jun 09:45:11 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
TEST-org.geoserver.gwc.GWCCatalogListenerTest.xml:29 Jun 09:45:11 ERROR [layer.TileLayerDispatcher] - Configuration /work/geoserver-2.0.x/src/gwc/null/../resources contained no layers.
TEST-org.geoserver.gwc.GWCCatalogListenerTest.xml:29 Jun 09:45:11 ERROR [layer.TileLayerDispatcher] - Error reading service information from /work/geoserver-2.0.x/src/gwc/null/../resources: Error parsing file /work/geoserver-2.0.x/src/gwc/null/../resources/geowebcache.xml
